I can resize my drawing, but then I have to do a mental multiplication or division each time I need to measure something or have to manually input dimensions as the actual scale is not a "true" scale, the XYZ dimensions are not the actual dimensions.
Basically, ArchiCAD allows for a drawing to be a fraction of its original size which is what most Architectural drawings typically are, but it does not allow to work at multiplied scales.
The object I am working on is very small, working in milimeters, so I am trying to draw it 10x its original size (yet looking for a scale that would allow XYZ coordinates to be accurate), but ArchiCAD does not allow such scale.  It allows 1:10, 1:20, etc...  But it does not allow 10:1, basically, it does not allow for scales above 1:1 if you see what I mean.
For now, I've done the "resized" and enlarged the original drawing 10x, but I have to mentally do the math constantly and manually adjust each dimension string.
Don't know if this clarifies my problem somewhat!?
Thanks!
