2004-04-0807:39 AM - last edited on 2023-05-2603:56 PM by Rubia Torres
2004-04-0807:39 AM
There are many criteria by which one can search in the Find & Select dialogue box. One that is missing is Composite. I want to change one particular composite in my model. I could use the Attribute Manager, but F&S would often be much quicker and is more powerful, in that it can be combined with other criteria, such as layer.
Dave Jochum J o c h u m A R C H I T E C T S http://www.jochumarchitects.com MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
Thanks for the heads up. Actually, you can select Walls and then add Fills as a further choice, and only wall type fills will show in the choices, including composites. If you choose Fills as the main criteria, then Fills as a sub-choice, only 2D fills show. Works just as I wanted.
Regarding the poll . . . never mind.
