Settings for doors, windows and other objects
Hi, I have a question.
Whenever I assign some settings to a door or window, let's say, a door with two sidelights, and then I click another type of door, metal door for example, the settings change, and when I click again to the door I assigned the settings before (door with two sidelights) now my settings are gone: pens, measurements... it resets
Is there a way to have a custom default settings on this?
Thank you
Dontknow
I think you'll find your answer here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=242813&highlight=#242813
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thank you so much! This really helped
