Shell - Ruled - Detailed
i have three profile polygons (morphs) that i want to use to create a shell.
Using the method ruled and detailed Archicad allows me to do it with only two profiles. So 1 with 2 and 2 with 3 produces two shells.
Is it possible to do all three at once?
No, a ruled shell can only have 2 profiles.
You could then convert these to morphs an then union them.
Or you could add morph lines and surfaces to the morph planes and again union them altogether if you need to.
