ChrisKlms
Curved roof with a slope and two different curves
Hello, beginner here,
I have a Ruled Shell defined by two arcs at different heights. The shell is flat/diagonal but I need it to follow two curved profiles which are arcs with different central points (low at the inner edge, curving up and over to a higher outer edge, see attached plan with center of curves). See screenshot attached. The red line shows the desired profile in section. I can't seem to modify this "section plan" as it follows my curve. I tried many other tools like slab, roof, wall but nothing seems to work and shell is the closest I got. I am not very familiar with the tool, is it possible to obtain my desired profile ? It has to be a single simple shape as I use it for rendering etc. so It has to be easy to modify, I'm sure it's possible as it's a very simple shape but I spent the afternoon trying to make it work.
Thank you for any help
Curved roof with two various curves.pngplan of curved roof and central points.png
6 Replies 6
cuba
So you want a roof with varying curvature, where the eaves line is consistent (horizontal) everywhere, and the ridge line is also consistent (horizontal) everywhere. The roof does not lie in a single plane, but each rafter has a different pitch.
Apple M1 Max 32 GB
Latest AC
runxel
First draw your shell with this method in the floor plan
Then rotate it in 3D 90° so its axis is parrallel to the Z-axis.
Back in 2D the trick now is to use the menu command "define shell contour". You can then draw the portion of the shell that you want to keep.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Lingwisyer
Guru
"curving up and over to a higher outer edge"
Modifying the shell contour will make the edge change height, even more so if it is not a straight pitch from inside to outside...
Ling.
runxel
That is true – but it is not what the OP has drawn.
It's still totally possible to achieve that, but now we need SEO to accomplish that (by using a vertical moved copy of the same element):
Patrick M
hmmm... not sure about the exact design, but seems a complex profile beam with a taper and/or segments may help get you what you need. for a lot of curved/round/etc. elements like this, I lean on other platforms (rhino is way better at this)
cuba
Note to myself: for a simple shape there must be a simple solution:
Draw a slab, convert it to a morph and move the corner points... (use another slab as a reference)
Apple M1 Max 32 GB
Latest AC
