Archicad design tools: Workflows, element connections, modeling tips
Shell/SEO Glich
Chris Grantham
Has anyone seen this behavior before? I am trying to SEO a shell with a bunch of slabs to create a canopy effect, but for some reason a bunch of the shell loses it's material, even though it is not SEO'd . I've attached a couple pictures to illustrate what I mean. Anyone have any thoughts?
Thanks in Advance!
-c
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
5 REPLIES 5
Chris Grantham
Here is what it looks like before the SEO with the slabs as wire frames.
Mac OS 26
Chris Grantham
FYI I have tried re-creating the shell with a complex profile wall, but am still getting the same result.
Mac OS 26
Erika Epstein
Your many curved holes may be stressing the shell. To test this you could try SEOing 1/4 of the holes and then adding another 1/4 of the holes etc to see when the number of holes is too many?
Then you could split up the shell into sections. Will it be manufactured in sections?
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I tried the same but without seo, using 'define shell contour' and 'create hole in shell' functions. The key is to divide in small parts as shown on my screenshot, it is very slow if I create a complete shell shape but as soon as I do a part of it and then duplicate it works fine
Chris Grantham
Til I totally forgot about that option. Thanks! Interestingly when I give the shell a little more curve there is no problem with the SEO.
Mac OS 26
