Streamline your workflows and master BIM coordination! Program starts April 28.!
Shell hole selection
Milan
Hey,
Im modeling building with a shell tool, and i have a hole on it which I want to edit. Its almost impossible to select that hole in 3D. Im doing something wrong or the tools is wrong?
Thanks!
You should be able to click on the edge or corner nodes of the hole.
The entire shell will highlight, but only the shell will have nodes that you can edit.
You might need to show us a screen capture.
Hey Barry!
Thanks for your assistance as always. Im not shure that i can share the screen because of confidentiality, but it seem to be working, bot not on every edge. But will try to use this option!
Setup info provided by author
