Short Key List for Archicad also List of library parts
Does anyone know where I can find the Short key Commands list. I stumbled upon it once and printed it out, can't remenber where it was.
Also the Achicad library parts list, same thing.
Thanks Kindly.
Ry
4 Replies 4
Ry
If you go Options> Work Environment > Keyboard Shortcuts, there is a tab at the bottom of the Work Environment window 'Show Shortcut List In Browser'
Open that up and then print it out.
As for a list of library parts, I'm not really sure.
Kristian wrote:
Ry
Hi Ry
Above works great, except it's not alphabetized. (Silly Archicad)
So if you highlight them all>copy>paste into excel and sort>(then maybe make a couple of changes depending on you needs)>then print, it's a bit easier to look them up.
Attached is zip of my excel'd AC shortcuts, (yours will no doubt be different).
Edited: Opps, see Non customizable ones at end of list did not get alphabetized, oh well.
Erich
Ry,
I don't know about other localizations but in the US version select the "ArchiCAD XX Library Guide" out of the Help Menu. This will take you to a GS website where you can download a PDF showing each library part. Perhaps your localization has this too?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Wow! you folks are fast
Thanks Kristian, I found short-key list just as you noted. and thanks lec
for the x-cell download.
Hey Erich I found Archicad 10 library guide on the archicad web but so far have'nt found Archicad 14 library guide /list, thanks though, still looking.
ry
