Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Short Key List for Archicad also List of library parts
Does anyone know where I can find the Short key Commands list. I stumbled upon it once and printed it out, can't remenber where it was.
Also the Achicad library parts list, same thing.
Thanks Kindly.
Ry
4 REPLIES 4
Ry
If you go Options> Work Environment > Keyboard Shortcuts, there is a tab at the bottom of the Work Environment window 'Show Shortcut List In Browser'
Open that up and then print it out.
As for a list of library parts, I'm not really sure.
Kristian wrote:
Ry
Hi Ry
Above works great, except it's not alphabetized. (Silly Archicad)
So if you highlight them all>copy>paste into excel and sort>(then maybe make a couple of changes depending on you needs)>then print, it's a bit easier to look them up.
Attached is zip of my excel'd AC shortcuts, (yours will no doubt be different).
Edited: Opps, see Non customizable ones at end of list did not get alphabetized, oh well.
Erich
Ry,
I don't know about other localizations but in the US version select the "ArchiCAD XX Library Guide" out of the Help Menu. This will take you to a GS website where you can download a PDF showing each library part. Perhaps your localization has this too?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Wow! you folks are fast
Thanks Kristian, I found short-key list just as you noted. and thanks lec
for the x-cell download.
Hey Erich I found Archicad 10 library guide on the archicad web but so far have'nt found Archicad 14 library guide /list, thanks though, still looking.
ry
