Hasselaar
Shortcuts renovation filter existing and new
Hi, is it possible to assign shortcuts to switch quickly between the existing and new renovation filer? Or is there a menu or palette that you can switch just with one click? (And not with the pull up menu on the bottom).
4 Replies 4
vlahtinen
Hasselaar
Hi Vlahtinen, thanks for your reply 👍
It's not what I'm looking for. I often switch a lot between existing en new, and everytime I have to do multiple clicks to change the renovation filter. It would be a lot faster and easier if it could be done with a shortcut.
The thing is, there can be many renovation filters.
So you would need a shortcut to pull up a list and then choose the one you want (which is not possible as a shortcut, but can be in a menu).
As it is now it is only 2 clicks, one on the renovation filter button at the bottom of the working window to pull up the list and one to pick the filter.
So there would be no benefit except that you would not have to move your mouse to the reno filter button.
Erwin Edel
If you setup two views and put them at the top of the list, you can quickly swap between the two by simply double clicking on the view.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
