2011-10-19 12:48 PM
2011-10-19 02:51 PM
Aquavit wrote:1. Import it on an empty Worksheet at its original coordinates (File/External Content/Attach Xref...). This worksheet will be used to read real coordinates.
Hi, I have a UK Ordnance Survey map, in 2D DWG format, which is to be the basis of my site plan & project.
I was planning to merge it into a lower story and use it as an underlay...
Aquavit wrote:I don´t know nothing about British grid system, sorry.
The OS map is on the British grid system, can I set Archicad to those coordinates or is it only WCS?
2011-10-19 03:15 PM
andro55 wrote:Perfect thanks, brings it into the right location. To get it to scale correctly all I have to change the DWG translator to read DWG unit as 1 meter.
andro55 wrote:I'm not sure I understand why I need a second copy of the OS map for the plans. Would I not model the various buildings/phases in a separate file and trace those into my Geo-Located site plan?
2. Repeat the point 1, only put it at coordinates x=0, y=0. This worksheet will be used as Trace Reference for your PLANS.
2011-10-19 04:58 PM
2011-10-19 05:07 PM
2011-10-19 08:29 PM
