Slabs
Hi everyone. I'm trying to create a slab to a certain thickness but the box for entering the slab thickness is ghosted. I have never come across this before, what do I do now?
Hi Maud,
it is because you've selected a composite slab structure.
I don't know what version of AC you're on, but if you go into the slab's settings dialogue box and locate the settings for the slab's fill and select a fill that is not a composite youäll be able to set your thickness to the slab again.
Thank you!
