SOLVED!
Solar panel Object
William Gray
Does anyone know how to activate the support option for the Archicad 25 library solar panel objects? All 3 solar panel objects in the library have a greyed out option for "Support" under Style and Dimensions.  Changing the criteria of number of panels etc. seems to have no effect and the option remains greyed out.
undefined
William Gray
Architect
Archicad 25 INT Build 4013
MacBook Pro Intel Core i7 2.9 GHz 16GB RAM
Mac OS 11.6
1 ACCEPTED SOLUTION
Solution
vistasp
Once you change the angle to something other than zero, the box should become selectable.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
2 REPLIES 2
Solution
vistasp
= v i s t a s p =
bT Square Peg
Many thanks - as always- so simple!
William Gray
Architect
Mac OS 11.6
