go
William Gray
since ‎2005-01-11
3 weeks ago
User Statistics
  • 30 Posts
  • 0 Solutions
  • 2 Likes given
  • 1 Likes received
User activity
I want to create a window with a negative reveal externally (ideally with a chamfered angle) and splayed reveals internally (but each internal side with different angle). The custom reveal allows for internal and external reveals but the reveals to each side are rectangular ...
More of a wish than a question! Is it possible to have a single double hung (sash) window using the Archicad windows which has asymmetric sashes (ie a smaller top sash with, say, a single vertical pane) and a larger lower pane ) with, say, two vertical panes?
Does anyone know how to activate the support option for the Archicad 25 library solar panel objects? All 3 solar panel objects in the library have a greyed out option for "Support" under Style and Dimensions. Changing the criteria of number of panels etc. seems to have no ef...
When I open my template, the floor plan window is no longer attached to a tab. If I open an elevation, section or other view, they open up correctly within the tabs. But if I select any floor plan view, a separate window opens (which has no link to a tab) and a header to the...
Is there a method of speeding up the editing of an interactive schedule? I have a schedule which creates a detailed specification for all new items within my building model. If I edit an object, wall, roof etc. within the interactive schedule, the schedule refreshes itself b...
Likes given
Likes received
