2022-04-15 06:42 PM
More of a wish than a question! Is it possible to have a single double hung (sash) window using the Archicad windows which has asymmetric sashes (ie a smaller top sash with, say, a single vertical pane) and a larger lower pane ) with, say, two vertical panes?
2022-04-16 02:23 PM
I don't know about the INT version, the USA version library has those options.
David
2022-04-16 11:41 PM
That's most helpful. There's a much better range of choice in the USA version. I wonder why the INT version doesn't the same options! Many thanks
2022-04-19 03:46 AM - edited 2022-04-19 03:50 AM
You can do the divisions with the AUS / INT windows, but not the size difference...
