William Gray
Asymmetric Single Double Hung Windows
More of a wish than a question! Is it possible to have a single double hung (sash) window using the Archicad windows which has asymmetric sashes (ie a smaller top sash with, say, a single vertical pane) and a larger lower pane ) with, say, two vertical panes?
William Gray
Architect
Archicad 25 INT Build 4013
MacBook Pro Intel Core i7 2.9 GHz 16GB RAM
Mac OS 11.6
3 Replies 3
David Maudlin
William Gray:
I don't know about the INT version, the USA version library has those options.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
William Gray
That's most helpful. There's a much better range of choice in the USA version. I wonder why the INT version doesn't the same options!  Many thanks
William Gray
Architect
Mac OS 11.6
Guru
You can do the divisions with the AUS / INT windows, but not the size difference...
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
