jd10003
Spanish Tile Roof Eave Modeling Help
Do you guys have any ideas for how to model the traditional clay tile eave condition in my photos below?
I'm using the built-in roof surfacer set to "Italian Tiles" and have my ridges covered with the built-in Ridge Tile object.  I can rotate the ridge tile object in plan and in elevation to accommodate my roof slopes....I was hoping I could rotate it in section to create that eave condition, but it won't do that.  This is a very typical condition in a lot of my upcoming projects so I'd love to find a solution!
Any ideas???  thanks
2 Replies 2
jd10003
Once more, in case the photos didn't come through in the original post
You would need a barge object that can do tiles along its length.
I an not sure if there is an object that does this in the default library as I don't use it and don't have Archicad in front of me at the moment to check.
Or maybe you could use a segmented inclined beam with tapered profiles?
