Stair railing display
I have created a stair using AC10 generic stair tool, not stair maker, and I cannot get the railings to show up in plan view. Everything is good in Elevation and 3D. How do I fix this with?
3 Replies 3
Laura Yanoviak
Not know which object you are using, I can only offer one suggestion: check your drawing scale/2D Detail Level setting -- if the setting is "Scale Sensitive", the handrail will not show at smaller scales -- "Custom" will display the symbol per the parameter settings.
Thank you! I checked the setting and it is set to custom. The object is "Stair Straight RC 10". Any other suggestions would be awesome!
Laura Yanoviak
I believe it's your 2D Symbol Type -- in the screenshot below, I've used Type 14.
