StairMaker Ramp Error PGON what does it mean?
I know I will get screamed at WHY DO YOU USE StairMaker, yet I keep thinking one day I may figure it out; but until then:
What does this PGON error message mean when I am trying to save the Ramp?
By the way after trying to create this ramp with StairMaker I gave up after 45 min. and created it with Slab and Roofs then input the lengths into StairMaker as a check then the geometry worked!!!
Maybe this method to be used for Stairs/Ramps so we can get the benefit of the railing functions?
Thanks,
Joseph
5 Replies 5
Is it that no one has encountered this message or no one uses the StairMaker Ramps?
Thanks
Joseph wrote:
I know I will get screamed at WHY DO YOU USE StairMaker,Joseph
ok.. i agree that stairmaker is not " perfect " but its not THAT bad... i donno...after using the program for almost 8 years... i like it
Link
I vaguely recall that being a polygon error that usually pops up when you have intersecting tread noses, which happens in the corners. Stretch out the corner space a touch and see if that stops that helpful little error warning from appearing.
Link.
Well in 8 years I may let you know if get to your place!
Link, thanks I will try that, but wait, it is a ramp and not a stair?
Link
Probably not a nosing issue then!
Try spreading out the geometry anyway and let us know how you get on.
Link.
