Learn more
Storey Markers In Elevation
Does anyone know how to turn off the story markers in an elevation? I'm using AC10.
Thanks
4 Replies 4
David Maudlin
Tom:
Select the section line(s), open the dialog box for the Section/Elevation tool, under the top section "General", at the bottom is the pop up list for "Show Story Levels in this Section". You can also access this dialog box from the Section/Elevation window by right clicking in the window and selecting "Section/Elevation Settings..." from the context menu.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Also, if there is one story marker in particular you desire to not show up and the rest to stay turned on you can to into design>story settings and uncheck the box next to whichever story you would like turned off.
Thanks.
Johann_P
Dusting off this topic from 2007.
I'm trying to show and hide different storey markers in different sections and elevations, but I only seem to be able to hide a storey marker globally.
ie.
In Section AA, I would like to show Storey 1, 3 and 4. No other storeys.
But in Section BB and North Elevation, I would like to show Storey 1, 2 and 5. No others.
Is there a way to do this?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
