Strawbale home.
Arcadia
Anyone know how I can simulate the organic rounded corners and opening reveals of the walls of an earth rendered strawbale home?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
1 REPLY 1
vfrontiers
Polygonal walls, complex profiles and Solid Element Operators come to mind.
1. Place a polygonal wall "patch" at the corners and radius the outside edge to your specification. Should join seamlessly to the adjacent straight wall.
2. Straight walls can have a complex profiles to suggest a RADIUSED TOP.
3. Using tube shell objects or complex profiles, you can create CUTTERS to shape window openings and wall top radiuses. Remember to set your OPERATORS layer to a different WALL PRIORITY so the cutters don't try and intersect with your regular walls.
This is sort of a "nutshell" version of an answer. Let me know if I can explain more...
I am sure there are other ways as well.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
