Teamwork Master Sheets
genarch
I cannot figure out how to edit the Master layout sheets in a Teamwork file. When I select my workspace, the Master sheets are not available and it doesn't seem to matter whether I log in as Team Leader, Teammate, Administrator, etc. Anyone know how to do this?
MacOS Sonoma
AC28, Artlantis 2020, TwinMotion
Mac Studio M2 Max 2024
5 REPLIES 5
TeamLeader exclusive access?
genarch
That does the trick. Unfortunately, no other team members can be signed in if you want exclusive access, so you have to wait until no one else is working on the project in order to modify a master sheet.
MacOS Sonoma
vfrontiers
Did you try TEAM LEADER without exclusive access?
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
genarch
Yes, it doesn't work. You need to have exclusive access to edit the master sheets.
MacOS Sonoma
Link
The Teamwork cheat sheet I posted here may be of help in the future.
Link.
