The fill gets invisible?
What to do when some wall loses their fill,
when I update the sections?
It seems like the walls become invisible..hmm
NB, It's only in section and layout book view,
not in 3D (3D use image, not fill)
Please help
This is what I would do:
- double check if the wall has a fill attached
- double check if you have "vectorial hatching" in display settings
- if you can actually see thru the wall it means either it is transparent or corrupted (sometimes bad library part as window or door can corrupt whole wall - check that too)
- select the wall, open dialog window, click OK - it will refresh it parameters
- redraw section line, try again
HTH, Cheers
Edit:
I don't need to tell you that in Section Tool Settings -> Model Effects there is option "Vectorial 3D Hatching" that need to be checked, do I?
