Marky
To deactivate CineRender add-on?
Since I use Octane the CineRender is not of much use for me but still eats up around 70 MB of memory for nothing.
Thanks,
Marek
AC 6.5, 13 - 19 Pl, OctaneRender for ArchiCAD, MoI 3D, Blender; W7 Pro 64;
i7-4790K/32 GB; GTX 980/4 GB
2 Replies 2
I just tested on Mac OS X ... presumably Windows will behave similarly...
If I simply rename the CineRender folder (inside the ArchiCAD 18 app folder) - then CineRender does not launch. Attempting to use it will give odd results. E.g., the render settings preview window just spins indefinitely - but using Internal or Sketch behave as expected.
70 MB of memory is absolutely nothing these days though - cannot have any meaningful impact on your computer whatsoever.
Marky
Yes, you're right, after all it's not a big deal..
It takes renaming not only CineRender folder but there are three files in Add-Ons/Visualization folder as well.
Thank you.
Marek
