rob2218
Trac reference......HOW TO MAKE IT PRINT?
So...what's the tip/trick/workaround for making a "Trace Reference" print?
Hopefully...not having to wait for AC16.
Screen snap shots don't work cause they aren't to any scale and bitmap file is definately NOT a vectora file.
thanks,
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
3 Replies 3
rob2218
sorry bout the title...that's TRACE REFERENCE...I typed and hit the enter too soon.
sorry.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Trace and Reference is mainly an drawing-aid. However you can print one Trace at the time. Simple go to the print dialog (File/Print) and there you can check Print Reference.
But the main method is to place an extra drawing on your layout and attach a grey-penset to it.
rob2218
HUMMM...NO, here's what I mean...Trace Ref of "Demolition" in blue, actual new construction in other colors....how do I "PRINT" the trace reference image to a scale, NOT a bitmap image rather a vectoral print which would show the trace reference showing up???
I tried the "print reference" button toggle on the printer and that didn't do diddly....thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
