Triangular windows (again?)
I am sure this issue was discussed before but here we go again (?)
I need to draw a triangular window on the right half of a gable wall. The left stile and bottom sill would be perpendicular, the long diagonal side parallel to the roof pitch. The window would be 4000mm wide, 1000mm high with a diagonal at 15°.
Can it be done?
H
5 REPLIES 5
Got it!
Henry wrote:
Got it!
GLAD !!
but i didn't get it!! i mean didn't get what u were trying to do
I think Henry was talking about what we call raked windows.
mmm... is it that hard? not sure ... if there is any in library... but it could be drawn with " wallhole " right?.. any way i made many of this strange shape so...? i am on the safe side !!
I used: Archicad Lib - Windows - Special windows - W Trapezoid Fix 10. Then just set the short stile down to whatever to get your 'raked' window.
H
