Trim to roof ??
When you change the roof slope walls' tops remains in old roof's slope. Should we draw all the walls again? Or is there an option to disable wall's "trim to roof" action?
3 Replies 3
Yup there is, select the wall, go to wall selection setting (ctrl+t), under model, you find "Undo roof trim", press this button and then ok.
It is an ancient wish to have 'undo trim' as a context menu when the wall is selected, but as TurboGlider says, you'll find the button in the wall settings dialog.
You might consider using Solid Element Operations to trim your walls instead...as the result is then dynamic: changin the roof slope, or plate height automatically adjusts the trimming, so no extra work or accidentally forgotten walls showing up in your sections.
Karl
Thanks Karl and Turbo,
It seems it is too much thing to learn.
Thanks again,
Have a good work...
