Trouble with Walls hatchings in AC10
Hello
We've just installed AC10, so we're starting to transfer files from 9 to 10; But I'm observing many problems with the posting.
For example yesterday my walls (custom one) appears as they must be, with a part of grey hatching, but today this part is white. Is there an ption that I could have check on without have seen it? I've already check, they're on first plan (on top), I'm using the custom wall option; i really don't understand.
TY
3 Replies 3
Could you have accidentally changed the Pen Set?
Richard
AC26 (since AC6.0), Win10
hi there, did u mean (posting) u were viewing the drawing on the layout? cuz i think im having same problem...fills appear solid on the layout book (AC 10). pls try selecting "colors defined by pen set" instead of "black and white"from colors in the drawing settings.
hope this helps...
Finally, it must have been a files trouble, cause I've saved it under a new name, with an AC10 file (fusion with a "virgin" AC10 file) and there's no more problem.
But this bad saving has caused many trouble with walls but also with titles and with the clic : you clic on point it's selecting a line 3cm above, very strange...
