ā2009-03-03 11:52 PM
ā2009-03-04 12:33 AM
ā2009-03-04 05:54 AM
ā2009-03-04 06:17 AM
ā2009-03-04 06:54 AM
ā2009-03-04 08:50 AM
mattsvai wrote:Try a smaller scale. (Such as 1:500 instead of 1:50)
WOW... for a second there I thought this was a BUG. I tried everything... and I found out that the line weights ARE WORKING. It's just that I need to zoom in ALOT to notice the change in line weight. How can I fix that? How can I make it noticable at regular zoom... I mean that's the whole point right? To notice it in the viewport
ā2009-03-04 05:51 PM
Thomas wrote:Well yes & no. Output maybe primary, but what you see on the screen is the way you check that prior to output. Coming from Microstation to ArchiCAD this was (and still is) one of my biggest adjustments. Microstation has a control that allows adjustment of the relative thickness of the true weight line on the screen to make it more visible when zoomed out. It would be nice if AC had this.
But the whole point is really to make a credible impression at final printout.
ā2009-03-04 08:14 PM
ā2009-03-04 09:44 PM
ā2009-03-04 09:49 PM
