True Line Weights?
Hi all,
I have 2 different lines with different line weights, I also have "true line weights" turned on and they still look hairline thin. Funny thing is, the line weights only show when I go to plot it. Any ideas?
Matts
11 REPLIES 11
Karl wrote:
If you are using a different pen set for display than for printing (which you generally should), then just beef up the pen weights in your on-screen pen set as required for your visual satisfaction.
This would serve to a point, but what I think he is looking for is a function that would exaggerate the lineweights in inverse proportion to the zoom. Personally I prefer to just zoom in to check here and there and trust the standards to produce the desired output.
Thanks for the tip Karl, I didn't know u could use different pen sets for screen and print. I will look into that. Great advice guys thanks alot!
Matts
