Typical Floor in ArchiCAD
We are fairly new with ArchiCAD 11 and work a lot with Multi residential buildings. As an example, with a condo with say 10 identical floors, is there a way to draw one typical floor and get Archicad to make multiple copies for each floor?
2 Replies 2
Srinivas
check for multi story hot link modules....
http://www.archicadwiki.com/Multistory%20Hotlinked%20Modules
http://www.youtube.com/watch?v=MsKLOowVw5M
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
You build one typical floor and save it as a separate file. This file can be .mod or .pln format
Then create a new file, set stories and using hotlink module to "plug" your typical floor into it.
File>External Content>Hotlink Modules.....
Good luck
Cheers
