U shape stairs direction???
Hello
I encounter many problems with the stairs tool
I am doing stairs U shape....but I get it the wrong direction...mean need
the arrow will go downstairs...not upstairs....
How can I change this? whare is the botton?
10 Replies 10
another thing.....where I can manipulate the rail style??? any ideas?
thanx
This image should be self-explainatory.
thanx !
what about rail style??? how?
If the rails can't do what you want you will have to find a separate object that does or make your own from profiles, columns, etc.
it doesnt work !
it is only changed in 2d plan...but I need to fleep the stairs direction
in 3D view....
How?
I thought you just wanted to show the direction going down rather than up.
No this won't alter the stairs in any way.
All you need to do is rotate and mirror the stairs just like any other object.
Use "Flip" in the stair selection settings (see picture).
Or if you mean you want the stair to actually go down from the active floor level amend the base level or insert the stair on the next level down.
thank u ...the X works....
I have another problem....when I attach the stairs to the podest of the
floor...now I dont have a rail of the podest......how I can creat the same rail
connected to the stairs rail???
Hi
Ok...now I know how to make the stairs. thanx !
but how can I connect the stairs rail to the podest?
I mean...How I can genereate rail podest (landing?)
consecutively to the stairs rail??
