UN-trimming wall to roof
After using the trim wall to roof command in one scheme I now need to lower the wall back to a height that does not trim to roof. When I try to reset the height of the wall I get no reaction out of the program. How can I accomplish this? Undo command is not an option in this instance.
Thanks,
Mark Hendricks
2 Replies 2
Under the wall setting, under "Model", there's a "Undo Roof Trim" button. Click on it and the wall resets.
Now, as for using the "Trim to Roof" option, why not just SEO the roof from the wall, and then you won't have to worry about this at all. I found this to be a cleaner and simpler solution.
Thanks Sergio,
Thanks for the info on the undo trim command.
I will take your suggestions and begin using the SEO with the roof as an operator. I have used SEO with stairs as an operator for raked walls.
Mark Hendricks
