Unable to save as ArchiCAD project 20
I'm in the middle of a project and wanted to save it as an sketchup file and afterwards I'm no longer able to save my projects as an Archicad 20 project only 19, which I find really weird.
I have Archicad 20 Educational version. Don't know if you need any additional information
Thanks for the help!
So if you do a 'File Save As', do you see the option for an 'Archicad Solo Project'?
I am not sure if it is any different on the EDU version as I don't have it.
The first option in the list should be the default version 20 file type.
The only option is Archicad 19 Project, Archicad Project Template, Archicad Archive Project and Archicad Object File. I've managed to solve the problem by creating a new project and coping everything into that file. So I've solved the problem for this specific project but its a problem that might appear again in other projects and make it all a bit harder.
Appreciate the help!
