Link
Undocumented Improvements in AC15
Here is the beginning of a list of 'minor' fixes in AC15 that I was personally involved in. I hope that others may be able to add other undocumented improvements to it:
1. Mirroring text now mirrors the anchor point.
2. The Help menu search function is no longer case sensitive.
3. Fill Area Text's are transferable via the eyedropper/syringe.
4. Project North now accepts up to 4 decimals (when set in working units).
5. Right click on Layouts and Masters to edit their settings.
6. Module Save Options have a new display setting.
Link.
56 Replies 56
Rafal SLEK
MacOs:
Project Preview for files (PLN) and library parts is working in Finder (!) 🙂,
and not only for v. 15...
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
I'm not sure what the definition of 'undocumented' is, but I notice there are some changes to the GDL master window when you open up an object.
The main one is a new search box to help you locate a particular parameter name - a nice little addition especially as the list seems to get longer and longer as objects become more sophisticated.
It is documented, but not in the new feature guide:
Launch new instance of ArchiCAD when opening a project from the recent list or by dragging onto a running ArchiCAD:
Click this option to always start a new copy of ArchiCAD when you open a project from the “Recent list,” or drag a project file onto a running ArchiCAD.
see bottom option:
Rafal wrote:
MacOs:
OMG! I cannot tell you how much of a big deal this is for me. I download every available object from the depository, bimstop, cadimage, manufacturers ... wherever I can find but even though I have organised them into folders it is a pain to have to import the folder to inspect the contents properly
A small but very welcome feature
Yes, that's the thing that will move me to 15 . 🙂
In the 3D window, the orbit command works again! If you select something, though, is reverts to the behavior of th last couple versions.
some more by GS:
http://www.archicadwiki.com/ArchiCAD15ChangesGuide
Rafal SLEK
Master wrote:
some more by GS:
...yes — forgot about the Icon 🙂
Best
Rafał
No more plotflow?! This makes me sad. How else do people plot PLT files?
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
