Walls and story heights levels
quick question, if I change a Story Height from say 9'-0" to 10'-0" is there a way to make my interior walls adjust to the bottom of my clg/floor slab automatically without having to selection all of the interior walls and editing the height manually? Before you all say it I know this is not Revit, But I didnt know if there was a work around for this.
Thanks
No.
At least you can do a select-all, and enter the new height just once. 😉
[You can play games with extra-tall walls and solid element ops, but IMHO it is not worth the hassle, performance impact, effect on scheduling, dealing with magic floating hotspots, etc.]
Karl
