Unworking Elevation view
Hi, I would like to make an elevation view of my building. I simlpy insert "elevation view" (using the menu on the left side) and then I open it. It started to "calculate the objects" but it doesn´t finish. Even after half an hour!!!
Help me please.
Thanks
2 REPLIES 2
David Maudlin
kubkaslamak:
It looks like you have some objects in your project that have very many polygons. Go to Help > ArchiCAD 16 Downloads and download the Polycount add-on. After installing the add-on, open the Polycount palette and see which elements have many polygons. You may need to adjust these elements or move them to a hidden layer.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David:
Thank you very much David. I will try the add-on. I also add the signature, thank you 😉
