ā2008-07-24 07:24 PM
ā2008-07-24 07:58 PM
ā2008-07-24 08:32 PM
Braza wrote:Yes it is.
Is the reference hotspot (the one near the zone label) inside the perimeter of the walls?...
ā2008-07-25 04:08 AM
Joseph wrote:If you are placing the zone first you must be drawing it with the manual placement method.
When I place a Zone & following this action walls are Magic Wound around it; if the walls are moved, a followup Zone upDate does not work. Any reason why or work around?
Thanks,
Joseph
ā2008-07-28 06:30 PM
Barry wrote:Wow thats great, I will try that, I knew there must be a way. I use the Zones to create the spaces & massing of the buildings and then to place the walls quickly by Magic Wanding them.
You can select the zone and change it to an automatic zone either to the inside surface of the walls or to the reference lines of the walls.
This is done by changing the construction method in the info bar.
Now they will update.
