Using the favourites from another project?
Hello.. im having a question about archicad 13. i want to use some favourites from another project like stairs , walls , line types, windows with their particular settings in my actual project. How do i do that?
Thank you.
2 REPLIES 2
1. Open that another project with second AC13, select prefered elements, COPY, and PASTE into first AC13 with new project
2. Open that another project and save prefered elements to FAVORITES. Now open new project and activate the FAVORITES Palette (saved elements are inthere).
David Maudlin
mlegs:
From the Favorites palette, click on the small triangle at the upper right corner, with options to Save Favorites... and Load Favorites... which allows you to transfer Favorites between files. For more information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "Favorites" in the search box, in the results list "Favorites Palette" will lead to detailed information.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
