We value your input!
Ver 16: Composites in modules
Has anyone come across this problem:
I understand that composites within modules adopt the attributes of the composite of the same name as defined within the model. So if I amend a composite within the model, all the modules which contain that composite will update automatically.
This used to happen in ver 14; but in ver 16 I've found that it doesn't happen all the time. I ran some tests and found that some composites update in both versions, whilst others update in ver 14 only. In version 16, I have to open each of the modules in turn, redefine the composite in the module, resave it, and then update the model - which is a pain.
This must be a bug, surely?
2 REPLIES 2
Have a look in your attribute manager to see it the composite in your master file has the same index number as the composite in your module.
If the index numbers are different hen tecnically you have different composits so changing the master file composite will have no effect on the one in the module.
If they are the same index number then I am not sure what is happening.
But you can use the attribute manager to overwrite the composites in your modules rather than having to redefine the composite.
Barry -
The index numbers are the same. I tried using the attribute manager to overwrite the composites in the modules, as you suggest, but the 'append' and 'overwrite' buttons are greyed out.
My suspicion that this is a bug stems from the fact that this problem does not occur when I open the same model in Release 14.
I tried 'backward saving' so that I could avoid the problem by reverting to rel. 14 for this model, but this caused a crash on every attempt.
