View display of Detail drawings
Please note the two attached screenshots. The first shows the detail marker, and the second show the detail drawing. I need to see all elements in the drawing - not just the 'core elements'. I've looked through the settings, and can't find where to fix this problem. The 'Structure Display' option is greyed out.
This is the detail drawing showing only "core"
David Maudlin
LINZ:
In the Detail Window, after changing the Structure Display (via the Quick Options palette) to Entire Model, did you Rebuild from Source View?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
