View selected items in several viewports
Hello!
I have one question related to selection of items.
I am working simultaneously in 3 viewports (floor plan, section and elevation) and I was wondering if it is possible to view a selected item (from ground floor) also selected & highlighted in the section and the elevation in the same time?
I am using Archicad 22.
Thank you very much.
JS
2 REPLIES 2
felcunha
What you can do is:
- open the "Selections" palette (in the menu Window -> Palettes -> Selections)
- in your section or elevation view, click on the button "New selection set". Name it as you wish. Your selection will be stored.
- in your floor plan view, double-click on the name of your selection.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Thank you so much, that did help a lot.
