Erika Epstein
W Splayed Reveal 11 Wallhole opening not aligned curved wall
I'd like to use the W Splayed Reveal 11 (not available in later libraries) in a curved wall, but the wall hole it cuts is off by what seems to be the sill height value.
I've been playing with the script but can't isolate the wall hole portion to make the vertical adjustment.
The same opening in a straight wall the wall hole aligns correctly, it is only vertically off when placed in a curved wall.
Can anyone point me to the correct section of script?
TIA
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
3 Replies 3
Erika Epstein
pic
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Tracing script is beyond me, but ...
Olivier's page here has a splayed window opening, don't know if he has it working in sloped
or curved walls, however I imagine his GDL will be easier to diagram and modify.
I think the new reveals on AC14 window are a major improvement. See attached. I do see that your head splay does not match the bottom splay, I 14 object will do that also, I just didn't change the values.
HTH
Snap
Erika Epstein
Snap,
Thanks for your thoughts, but iIf you look at the image, you'll see I am after a splayed opening. There are many workarounds which I've completed. My specific question was for the help with the code fix. It would be useful to have when working with castles.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
