Polar Bear
WALL END TOOL
Good day All,
I am having problem with the finish look of wall ending made with wall end tool.
See attached image.
Anyone has some suggestions?
Thanks for you kind advices...
Best
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Wall ends are objects associated to a single wall.
They will not automatically trim with other walls/elements.
So you will need to perform Solid Element Operations or other editing techniques to trim side walls, roofs, etc.
Also you seem to have a problem with your surface texture hatch - seems to be rotated 90° to the 3D surface texture image.
