I don't have 'Solo' version, so I don't know what Work Environments come with it.
There should be a 'Standard Work Environment' that you can use that should have all of the default settings (including shortcuts).
I can't say if Solo has Explorer mode or not - I assume it would.
From the Help Centre I found this when searching about solo ...
Solo license
Solo licenses for Solo ARCHICAD versions are available in the UK, USA, Brasilia, South Korea, Hong Kong and in Japan. Solo version has the exact same functionality as the Full version except it doesn't include TeamWork, Cinema 4D rendering engine and Hotlink/X-ref capabilities.
So try changing to different pre-installed Work Environments.
Do you still have access to the Full version?
Maybe you could save out your WE from there and try importing it into the Solo version.
It might not work as Solo does not have all of the features of the full version - but could be worth a try.
In the full version "Explore Model" is the shortcut you are looking for.
I assume it will be the same in Solo if it indeed has this option.
