Wall Composites
Srinivas
I have a problem with wall composites. I created a wall composite with 230 mm brick as core and two plaster as its boundaries and also another composite with 140 brick and the same two plasters. The problem is as shown in the given attachment when I want to have the 140 brick wall in between the 230 composite the wall intersections were not proper as marked in the figure. Please suggest me what to do in such situations.
thanks in advance.
cheers,
Srinivas.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
4 REPLIES 4
Thomas Holm
General Error
The selected Attachment does not exist anymore
404 File Not Found: The File files/composites_293.jpg does not exist.
Srinivas
sorry here it is.
ArchiCAD Service
Mac, Windows 11
Link
Srivinas,
Try switching the reference line for the middle wall to the other side. Or anywhere but in line with the outer walls. Be careful though, because this can sometimes mess with the wall's vectorial hatching in elevation and 3D.
Link.
Thomas Holm
I would try making a thin plaster-only wall and use it to cover the faults.
