Wall dependencies
Hello,
I have a model of a house where I created slab using complex profile option. Below, there are walls which are cut using SEO to adjust them to the shape of this slab. Everything is fine, until I reopen this project, where wall is placed like there are no dependencies set (the wall is not cut the right way). I noticed that if I change intersection group number in slab Layer settings it is fine again. It is very annoying to change this every time, but I don't know what am I doing wrong.
I hope you understand my question
Thanks,
Rok
When you change your intersection group number in the Layer panel make sure to save it as a layer combination. It is possible that you choose another combination where the strength of the layer was different?
I hope you understand my answer.
Regards,
Thanks and I understand your answer. I forgot to save Layer combination. Now it works!
Thanks again
Rok
