SOLVED!
Wall tool not showing the guiding line, or recognizing corners.
Sally
When I am trying to draw a wall, the wall tool will not automatically show the blue guide line or recongnize corners or x/y-axis, so it is very difficult to draw walls straight or parallel to an existing wall.
How can I get the guiding lines back?
Thank you!
Operating system used: Mac Intel-based Sonoma 14.2.1.
1 ACCEPTED SOLUTION
Solution
David Maudlin
Sally:
Check that you have Snap Guides turned on.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
2 REPLIES 2
Solution
David Maudlin
Sally:
David
Sally
Thank you for the reply. I will add the Signature to my profile.
Setup info provided by author
