What´s wrong?
Something "funny" has started to happen.
When I click my first poin (wall, roof etc.) it just wont start drawing the line?? It just "blink" and nothing happens.
I can´t think of what is wrong, since I´ve done nothing to the program.
Jv
6 Replies 6
This may be a Video driver problem? The Wall may be drawing, but you just can not see the "rubber-band" have you clicked to start a wall and then clicked to end a wall?
Other Discussion is here.
Ok.
Maybe it´s the same problem.
But if I don´t just click, but hold down the mouse button, then I can see where I´m heading.
But, if i release the button, then the wall etc will be stopped exactly where i released it.
I´m using MacBock 2 GHz with 2 GB ram.
So, what do I have to download (or is there something to download for me 🙂 )
Jone,
You should check Options/work environment/ mouse constraints and methods
and see if you have "Mac classic-like" or "Cad-like" selected
in "Line drawing" options at the bottom of the control panel.
Change the selection and see if you get the behavior you want.
Peter Devlin
..You know..And so I did.. and it worked!!
Peter - thank U
SeaGeoff
Ace
Is it too much to ask that folks use more descriptive subjects than "What's wrong" and "Help"?
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Well, I´m from Norway - and, if I could write in my own language, then ok, I could write more directly.
But, thats life..hard as hell!
