Where is the Accessories Menu?
I just updated AC10 and loaded Accessories Libraries in the AC10 Library. But cant seem to find the menu " Design > Design Extras > Accessories" anywhere.
Any ideas?
HOW TO USE "Accessories" ADD-ON?
First, select an existing building element (wall, roof or slab) on the Floor Plan, and then choose the appropriate command from the Design > Design Extras > Accessories hierarchical menu.
The Choose Accessory Object dialog box prompts you to select an Accessory object. Set the object's parameters on the Parameters and Custom Settings panels. Other parameters (for example, the slope of a roof) will be set automatically when placing the object, based on the settings of the associated building element. Click OK in the Accessory Object dialog box, then click on the Floor Plan to place the Accessory Object.
Have you downloaded the add-on (Help -> Archicad 10 Goodies), and placed it in the Add-ons folder?
James Murray
Yeah.
I solved the problem. I reset my work enviroment scheme and pop there was the design menu right between view and document.
Thanks for your time.
